351 Mustang
351 limits?
Old Jun 19, 2006 | 05:33 PM
baddog671's Avatar
baddog671
Default 351 limits?
I read in here somewhere that the limit for a 351 is about 600-700, and after that it is in danger of breaking. How come I see cars in magazines with more than that then? I was at my friends house the other day and on the front page was a chevelle(i think) 350 with 1036 hp...
Old Jun 19, 2006 | 05:42 PM
P Zero's Avatar
P Zero
Default RE: 351 limits?
That limit is probably for the stock internals as in the crank. Because the crank is cast it can come apart with high HP numbers, if you get forged internals i.e. crank, rods, pistons it should be fine as long as you have it machined for 4 bolt mains. Other than that there might be "special service" blocks that are thicker, kinda like the Ford 302 sportsman block.
-P.
Old Jun 19, 2006 | 08:30 PM
S351R13's Avatar
S351R13
The "limit" is based on the block, the stock crank, rods, and pistons. RPM's kill the rotating assembly. To go further you have to upgrade. Do not have a production block machined for 4-bolt mains. It will actually weaken the block. You can take a sportsman 351 block and upgrade it to 4 bolt mains the right amount of material is there for it. I am not sure about the 302 sportsman block. Once you go past 700 rwhp with ny chevy, ford, mopar small block the stock internals become an issue.
JoshyGT
Sep 19, 2017 08:52 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
firehorse02
Nov 16, 2015 11:28 AM
treesloth
Sep 28, 2015 07:03 AM
uberstang1
Sep 20, 2015 06:42 PM
