351 Mustang
Bracing the subframe
Old Sep 7, 2006 | 02:07 AM
lemonademaker's Avatar
lemonademaker
Default Bracing the subframe
Hey!
Still kinda green on some areas of my 89 LX. It's got a 5spd + 351W. The previous owner had made a comment on the e-bay auction that I should brace the subframe before any serious hod-rodding. Is the mustang (1989) a body/frame style? What do I need to get? Would Summit Racing have it? Keep in mind, that it IS a 351 and I've just got my little stock hatchback with no structural mods aside from a rear seat delete. What do you recommend? I'd like some mods that keep it from flexing/twisting too much, while making sure it still will grab me by the seat of my pants and steer like a streamlined butterfly on those Colorado roads.
P.S. Any word on the fan size of a 351W? I have no idea about the of my engine, right now it's got a 15" fan, I didn't know if it was meant to run something bigger.
Thanks folks! Ya'll are the best!
Old Sep 7, 2006 | 02:43 PM
r.barn's Avatar
r.barn
Default RE: Bracing the subframe
www.maximummotorsports.com
you Full legnth , weld in sub-frame connectors.
you might want to have the Torque boxes re-inforced also.
Old Sep 7, 2006 | 02:47 PM
lemonademaker
what's a torque box?
Old Sep 11, 2006 | 10:54 PM
Arrid Extra Dry's Avatar
Arrid Extra Dry
go to a welding shop and by some metal and weld it in, its cheaper, and the sub frame connectors you buy... usually you have to modify anyway
Old Sep 11, 2006 | 11:22 PM
lemonademaker
weld them from where to where? and how much would it cost?
Old Sep 12, 2006 | 12:32 PM
4Stangs's Avatar
4Stangs
Get the full-length Maximum Motorsports subframe connectors as r.barn said. I've used them exclusively on my last 3 builds. They fit perfectly and come with clear instructions for welding. Definitely weld them for the best results. They sit flush against the front and rear subframes and connect the 2 into one solid piece fom rear all the way to the lower firewall (full-length).
I've used UPR's upper and lower torque box re-enforcement plates. They work ok. The uppers require removal of the back seat (if you have one), but that's easy. These pieces weld/bolt into place where the upper and lower control arms connect to the car. It doesn't take much to egg-shape the factory connecting bolt holes and crack the mounts where they are spot-welded to the car. Doing this before there is a problem will save you some headaches later.
P.S. About $200 for the parts.
guitarman376
Oct 11, 2015 01:47 AM
Sep 17, 2015 07:57 PM
Sep 16, 2015 07:53 PM
Sep 1, 2015 08:16 PM
