Build Ideas 351w
I want to build a 351w with something like 500-600 hp fuel injected....so can you tell me a good setup to achieve this, Im open to all ideas but I would prefer N/A and kinda streetable, Im not really familar with the 351 so I just need some help with good combinations and compression ratios
408W with 10:1 compression
AFR 225's
Jay Allen custom cam
TrickFlow 5.8L intake or CHP spyder intake or VicJr. EFI intake
42# injectors
80mm TB
90mm MAF
Long tubes
Should make around 500+hp at the crank.
or............
357-393W with 8.5-9:1 compression
Canfield 195's
Custom cam
GT-40 5.8L lower intake fully ported like a *****
Kennebell blow/flowzilla at 10-12psi
80-90mm TB
90mm MAF
60# injectors
Long tubes
INSANE power and torque.
AFR 225's
42# injectors
80mm TB
90mm MAF
Long tubes
or............
Canfield 195's
Custom cam
80-90mm TB
90mm MAF
60# injectors
Long tubes
