351 Mustang
AFR 185 question
Old Jan 2, 2007 | 03:23 PM
roblarss's Avatar
roblarss
Default AFR 185 question
Has anyone installed a set of AFR 185s on a stock 351w?
I am looking at a few 351w and was wondering if the heads will fit with outhaving to install new notchedpistons. Im trying to do a budget project right now. I will be doing a rebuild later when I have more time.
Old Jan 3, 2007 | 06:56 PM
Indy's Avatar
Indy
Default RE: AFR 185 question
roblarss,
my Edelbrock RPM heads with 2.02"/1.60" valves, had novalve-to-piston clearance issueswhen I had my stock cam and pistons. However, obviously the AFR's and Eddy heads are very very different.
when you get the heads,it's super easy to check your clearances (should be an automatic practice anyways!).
Indy
Old Jan 4, 2007 | 09:57 AM
roblarss's Avatar
roblarss
I will have to for sure check the clearances before I do anything. Im just looking at using the engine stock until I have enough time to do a rebuild on it. May have to do a rebuild before I do anything I guess.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
