351 Mustang
cam selection
Old Mar 18, 2007 | 04:16 PM
95viperred's Avatar
95viperred
Default cam selection
This is a big time newbie questions but what are flat topped cams, and are hydraulic cams an alternative to pushrods?
Camshafts
Since we’re assuming you’ve started out with a new or rebuilt 351 short-block, we’re not going to talk about camshaft or timing-chain choices, but there is one important detail that bares mentioning. Early 351W blocks are not designed for use with roller hydraulic cams. This leaves you with two choices: Run a flat-tappet cam, or make some changes so you can run a hydraulic roller. "We find that about 50 percent of our customers stick with the flat-tappet cam," George Klass says. "But that limits you to less-aggressive profiles because of the ramp rates [of a flat-tappet grind]." George says if you want to use a hydraulic-roller cam, you can use stock 5.0 roller lifters as long as you run a small-base-circle cam (also known as a retrofit cam), available through a variety of cam manufacturers
Old Mar 18, 2007 | 04:32 PM
atomsk680's Avatar
atomsk680
Default RE: cam selection
there are different types of cams
Hydraulic Flat-tappet
Mechanical Flat-tappet
Hydraulic roller
roller cams ae more efficient and can producer a little more power but you need more then just cam and lifters to use it
hydraulic flat tappet, basically is just a cam and lifters, most people choose this for their old block because their block came with this.
theres also mechanical cams but dont worry about them.
all of them require pushrods
Old Mar 18, 2007 | 05:00 PM
95viperred's Avatar
95viperred
so what do all the 351 require?
Old Mar 18, 2007 | 05:05 PM
95viperred's Avatar
95viperred
or what are the 351 engines set up for
Old Mar 19, 2007 | 11:50 AM
95RedGT302's Avatar
95RedGT302
Depends on what year your block is, I believe after 1986 ford 351w went to hydralic roller cams/lifters. You will need to look up the casting numbers on your block to see what year it was produced in
GimpyHSHS
19
Dec 19, 2023 01:12 PM
carid
Jul 8, 2016 09:55 AM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
