351 Mustang
351 guys only.......question
Old Jun 24, 2007 | 06:43 PM
90mustang5.8's Avatar
90mustang5.8
I ♥ Acer
Default 351 guys only.......question
what cam will work better with this combo? there both well matched but i want to know for sure.
edelbrock 210cc heads
edelbrock jr. victor intake (rpm range 3500-7500)
750cfm barry grant speed demon carb
cams: XE 294 (rpm range 2800-7000) FW 305 (rpm range 3000-7000) both by comp cams and hydraulic flat tappet
i was leaning towards the Fw 305...........what size torque converter should i get? 3000 or 3500?
thanks alot!
Old Jun 25, 2007 | 01:50 AM
90mustang5.8
I ♥ Acer
Default RE: 351 guys only.......question
bump!
Old Jun 25, 2007 | 05:20 PM
90mustang5.8
I ♥ Acer
no one knows?
Old Jun 25, 2007 | 06:03 PM
w8less's Avatar
w8less
ill help when i get back from work
Old Jun 25, 2007 | 11:51 PM
Matt Paul's Avatar
Matt Paul
Ill make it simple for you.I will buildyou the same motor in my sig for $7500 from carb to pan assmblied.Ive got your messages butIam not good with typing alot if you got the cash and are serious I will PM my phone number to you.I have dealt with Joel5.0he knows me and has seen my work.
Thanks Matt
Old Jun 26, 2007 | 12:13 AM
90mustang5.8
I ♥ Acer
no thanks
Old Jun 26, 2007 | 08:36 PM
90mustang5.8
I ♥ Acer
bump
Old Jun 27, 2007 | 06:35 PM
90mustang5.8
I ♥ Acer
TTT
Old Jun 28, 2007 | 02:54 PM
Force4's Avatar
Force4
its a nice combo but will cost you tons o $, Driving on the streets would be a waste of time having no low end at all, Drag car = good combo, street car = bad combo, also, those heads will probably require your pistons to be notched.
Old Jun 28, 2007 | 05:04 PM
90mustang5.8
I ♥ Acer
well my goal is to run 12 flat / high 11's with a combo but still be able to drive on the street. then i want to hit it w/ a 150 wet shot of nitrous to get some low 11's
