351 Mustang
GT40p heads
Old Jan 11, 2008 | 10:14 PM
ARYANW's Avatar
ARYANW
Default GT40p heads
i actually have a couple questions.
but to start off with can i and should i put gt40p heads off an explorer on my 351w?
Old Jan 16, 2008 | 06:35 PM
ARYANW's Avatar
ARYANW
Default RE: GT40p heads
Old Jan 18, 2008 | 01:52 AM
Ford1158's Avatar
Ford1158
Sure - just need to drill out the head bolt holes to 1/2". I set mine on a piece of plywood and drilled them in the press in two steps..
There's quite a bit of information on these if you look around a little.
Old Jan 18, 2008 | 09:01 AM
92cobra's Avatar
92cobra
+1 you do need to drill them, but they can and should be used. Gt40/40p stuff is great for cheaper builds.
Old Jan 18, 2008 | 10:28 PM
ARYANW's Avatar
ARYANW
ok great.thats what im doing..a cheap build.so just drill the holes out to 1/2in.
Old Jan 20, 2008 | 09:52 PM
ARYANW's Avatar
ARYANW
So nowwilla 302 upper and lower EFI intake bolt up?
Old Jan 20, 2008 | 09:58 PM
militarymustang88gt's Avatar
militarymustang88gt
no cause they will still be to wide considering it is a 351. it would be the same as bolting up a set of stock 351 heads on the block. you will still need a 351 lower. and you will need a 351 distributer since the bearing on the 351 is bigger than the 302.
Old Jan 20, 2008 | 10:07 PM
ARYANW's Avatar
ARYANW
i understand..but i dont.lol sorry im new at all this and always learning.soo if the gt40 heads came off a 302...and a lower intake was bolted up to that..why wouldnt it work now?
Old Jan 20, 2008 | 10:16 PM
militarymustang88gt
the deck on the two blocks are different and that is where it comes in.
Old Jan 20, 2008 | 10:21 PM
ARYANW's Avatar
ARYANW
ok.im just rethinking things because some guys at work are telling me to EFI instead of carb.idk what to do lol
