351 Mustang
Tremec 3550 problem!
Old Jan 13, 2008 | 02:20 PM
blueboosted95's Avatar
blueboosted95
Default Tremec 3550 problem!
My car is stiff in 1st and 2nd gear sometimes and ive adjusted the clutch properly to half inch of play at top and fluid is full so what could it be? it doesnt grind except in reverse a little
Old Jan 14, 2008 | 03:08 AM
P.S.I.cho's Avatar
P.S.I.cho
Default RE: Tremec 3550 problem!
explain stiff? as it doesnt want to come out of gear? or its hard shifting?
Old Feb 24, 2008 | 10:45 AM
Pacoloco83's Avatar
Pacoloco83
I had that tipe of trans before and the same thing hap to me,If im you i get a new trans and sell that one before you snap the gears trust me....A friend had the same trans too and it got stuck on 3th gear and after that everything inside
got fu.......t
Old Feb 24, 2008 | 01:46 PM
S351R13's Avatar
S351R13
Drain the fluid and make sure to replace the fluid with the correct GM synchromesh. Go to the GM dealer to get it. If you don't have the correct fluid it will do just what you are describing. DO NOT use automatic trans fluid like for a T5.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
