351 Mustang
fox 408w main girdle?
Old Jan 14, 2008 | 11:31 PM
94Cobrakid16's Avatar
94Cobrakid16
Default fox 408w main girdle?
anyone think a main girdle is necessary for a 2 bolt main 351 w roller with around 500-600hp?
if so what oil pan do you use to fit a fox?
Old Jan 15, 2008 | 02:09 AM
P.S.I.cho's Avatar
P.S.I.cho
Default RE: fox 408w main girdle?
you need the 351w swap pan, moroso sells one i believe, i always recomend the main girdles on any performance oriented engine, better safe then sorry
Old Jan 15, 2008 | 08:11 AM
92civy's Avatar
92civy
Yes For that HP (What I will be running) I would personally run a main girdle. but one that fits over the main caps without machining! I personally dont believe in machining th maps (Weakening them) to fit a girdle! But Yes Iwill be using one!
Old Jan 15, 2008 | 11:29 AM
w8less's Avatar
w8less
what will be your set up?
Old Jan 16, 2008 | 11:32 PM
94Cobrakid16
so far i got an eagle crank and rods, srp forged pistons, and with 58cc heads it will be 10.5:1 c/r. i got a fidanza flywheel and clutch, new harmonic balancer, and all that is balanced with the rotating assembly, plan on using afr 205 heads and a custom cam. other than that im still picking things out, i just got all this stuff back from the machine shop on monday so its still early in the project.
and it will be going into a fox
ORIGINAL: Jasperstang308
Old Jan 17, 2008 | 10:16 AM
01mustangracer's Avatar
01mustangracer
I ♥ Acer
looking like your going to have some serius power
Jan 21, 2016 01:30 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
