351 Mustang
351 build
Old Feb 1, 2008 | 04:00 PM
65nova's Avatar
65nova
Default 351 build
Ok, heres what I've go so far.
351 roller block
stock crank
forged I beams
forged pistons (not sure which ones yet)
RHS 200cc heads
vic jr intake
plan on getting proform race car (any suggestions on what size? motor will stay 351-7 and will probably be spun 6500 maybe a little higher depending on cam)
Lunati nitrous cam- not sure what lift yet the maching shop and i are still working that out
I'm thinking about getting valley and main girdles, are these going to be helpful or a waste of my money?
AJE tublar K member and manual steering rack
C4 tranny with manual valve body, stall is still being decided b/c cam isnt selected
373 gears
31 spline axles
electric fuel pump from a fuel cell
I plan on getting the vic jr drilled and trapped for a pro fogger kit and running a 200 ish shot give or take 50
What do you guys think, all input is welcome
Old Feb 1, 2008 | 04:05 PM
65nova's Avatar
65nova
Default RE: 351 build
o yea it will be mostly a strip car but street able, i dont need emmisions where i live so that is not a problem (or inspection)
Old Feb 2, 2008 | 01:51 AM
w8less's Avatar
w8less
ORIGINAL: 65nova
351 roller block
stock crank *be sure to have it all balanced especially with the rpms*
forged I beams
RHS 200cc heads * RHS is alright but i perfer different brands b/c of the results i have seen*
vic jr intake *port it if money allows*
plan on getting proform race car (any suggestions on what size? motor will stay 351-7 and will probably be spun 6500 maybe a little higher depending on cam) *check out pro-system carbs i hear patrick does awesome work*
Lunati nitrous cam- not sure what lift yet the maching shop and i are still working that out * i ran a lunati nitrous cam in my old 347 stroker nice cam pulled hard from 3-65 If i remember right it was the LUN-51018LUN*
I'm thinking about getting valley and main girdles, are these going to be helpful or a waste of my money? * main girdles help with main stability at higher rpms. valley girdles are junk *
373 gears
31 spline axles
read above
Old Feb 2, 2008 | 11:28 AM
65nova's Avatar
65nova
whats wrong with RHS heads? they guy at the machine shop said from what he has seen come though they are some of the best heads he has seen
Old Feb 5, 2008 | 11:50 PM
65nova's Avatar
65nova
so an update:
went down to the machine shop today and we figured out that:
Piston is going to be a forged 30 over speed pro flat top should put compression at 9.98:1 with a 64 cc head
RHS 215cc heads
custom ground nitrous cam
and the guy is short on help so i might get a job helping the guy with machine work which would be a good learning exp for me
Old Feb 6, 2008 | 02:58 AM
w8less's Avatar
w8less
sounds like a good plan should run like a bat out of hell
Old Feb 6, 2008 | 12:02 PM
65nova's Avatar
65nova
the cam is going to be ground to spin the motor roughly 6800 to 7000rpm and for a 250 shot
Old Feb 6, 2008 | 12:11 PM
militarymustang88gt's Avatar
militarymustang88gt
hey is it a comp cam? my buddys dad got one from them with like .689 lift at .050 with like 287* of duration
Old Feb 7, 2008 | 06:49 AM
65nova's Avatar
65nova
its actually a custom cam grinder that the guy at the machine shop knows he said he completely stopped going to comp b/c the cams this guy grinds generally pull about 50 more hp so it will be interesting to see what he comes up with
the specs he is using are
2800# car
3000 to 3500 stall
auto
nitrous
6.8-7k rpms
and maybe one other thing but i cant remember right off hand
Old Feb 7, 2008 | 06:49 PM
militarymustang88gt
yeah my buddies dad went through bennett racing and they sent him a comp cam. so he got the specs sent the cam back to bennett and ordered it from comp himself. charged him 110 more than what comp charged him.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
the5
Sep 19, 2015 06:13 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
