351 Mustang
hyd roller
Old Mar 19, 2008 | 10:51 AM
corvettekillerlx's Avatar
corvettekillerlx
Default hyd roller
is there and what year did the 351w have hyd roller?
Old Mar 19, 2008 | 01:44 PM
psuhillbilly150's Avatar
psuhillbilly150
Default RE: hyd roller
Roller block is 94 to 96 only.F4TE casting. Thank S351R13 for that info from a previous post.
Old Mar 19, 2008 | 02:22 PM
92civy's Avatar
92civy
The 92 lightning blocks were roller equipped right? But Never had the roller lifters in there. I know the F4TE casting are roller FOR SURE!
Old Mar 19, 2008 | 02:59 PM
corvettekillerlx
what kind of setup are you running?
Old Mar 19, 2008 | 04:29 PM
92civy's Avatar
92civy
Which one of us? I am going to assume me, as his setpu is in his Sig.
So I have a Probe forged 408 stroker kit. 4" crank, 6.125" I-Beam rods, 4.030" Pistons. I got a 74 block, and will have a super vic intake with ported windsor sr. heads or Vic Jr heads (Haven't purchased them yet) All topped by a pro systems 850 REALcfm carb
Old Mar 19, 2008 | 04:43 PM
blwn93gt's Avatar
blwn93gt
92civy,
you gonna run flat tappets or a linked roller lifter setup? i am thinking about finding a roller block but the older blocks are stronger (and more readily available). i just dont wanna have to spend $500 on a linked roller setup.
Old Mar 19, 2008 | 06:39 PM
92civy's Avatar
92civy
I will be running a linked solid roller lifters!
Old Mar 19, 2008 | 10:51 PM
bighungrymatt's Avatar
bighungrymatt
you can buy some used linkbar lifters for $250 or so
Old Mar 20, 2008 | 05:37 AM
blwn93gt's Avatar
blwn93gt
it just seems like a bad idea (to me anyway) to run used lifters on a new cam.
Old Mar 20, 2008 | 03:07 PM
92civy's Avatar
92civy
I have a set of used solid roller lifters. They will work fit! Since there is practically NO break-in for roller lifter/cam the wear on them is NONE! But for Flat tappet I wouldn't use used liftres. Partially because the wear pattern on the lifters isn't the same as the cam. So YES it can be broken in to work FINE! But thats my take.
