351 questions
I really don't know anything about a 351 block... So my first question is this a 351 W? How do you tell?The guytold me it was and it came out of a 77 Granada and I found the following info on that model car.
The '75-'80 Granada/Monarch was based on the '69-'77 Ford Maverik / Mercury Comet.
4 Engines Available:
200 3.3L I-6 1-Barrel Carb 72-76hp
250 4.1L I-6 1-Barrel Carb 97-98hp
302 5.0L V-8 2-Barrel Carb 134-139hp
351W 5.8L V-8 2-Barrel Carb 144-152hp
My next question is $200 a good deal for the complete motor and C4 trans? It was running when he took it apart, but he ran out of moneyfor his project. I really wasn’t looking for a 351 but it fell right into my lap. If this is a 351W is there anything bad about this model/block?
Pics below.
Pics below.
well it says 351 in the cam valley so yes it is a 351w... i can't read the pad bellow were it says AA2 but that is where theyear code is, i can see a 2 but that is it... is there much of a ridge at the top of the cylinder???
you can tell its a not a cleveland b/c the timing chain is not incased with metal, like a cover built into the block. I think it should also have a "W" next to 351 in the valley. The only thing bad with that year for those blocks is not roller equiped, but thats a personal preference and it does not use a one piece main seal. but they are supposed to be of the stronger blocks and the 2 things i mentioned can be fixed.
those cylinder walls look pitted.
75-76 351W BLOCK ID # VIN CODE "H" HEAD ID #
D4AE-
D9AE-
D5AE-, D5TE-
Notes: CARB, W TE
77-83 351W BLOCK ID # VIN CODE "H,G" HEAD ID #
D4AE-
D9AE-
D5TE-, D7OE-, D8OE-
Notes: 2-B CARB, W TE Heads, Uses 2-pc. rear seal until 7/11/83, front cover or pan mounted dipstick
There you go. And If the block is machinable to .030" over and the C4 runs perfect I say offer $150. Althought 200 isn't toooo bad. Have fun and build it big!
D4AE-
D9AE-
D5AE-, D5TE-
Notes: CARB, W TE
D4AE-
D9AE-
D5TE-, D7OE-, D8OE-
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
