351 Mustang
accessories questions
Old Apr 13, 2008 | 08:54 PM
86Capri2GT's Avatar
86Capri2GT
Default accessories questions
alright i just bought a 351w and it came with no brackets no altenator no power steering pump nadda the only thing it has is a water pump and crank pulley. right now i have a 1990 lx with the 4 cyl in it can i use the power steering pump a/c pump off of the 4 cyl? also what can i do for the altenator? i want to convert it to serpentine belt but have no knowledge of what i need and the brackets i need also any help would be greatly appreciated also i wanted to get a new dampener any suggestions
Old Apr 14, 2008 | 10:01 AM
r.barn's Avatar
r.barn
Default RE: accessories questions
You have to buy brackets.
Ford Racing makes swap bracket for the a/c and p/s
and you use stock 5.0 alternator bracket.
www.50resto.com has the brackets.
Old Apr 22, 2008 | 03:49 PM
tazman03's Avatar
tazman03
You will need the brackets for sure, but the Power steering pump will swap over to the new bracket. ( I am pretty sure.) if you look at every ford all the pumps look identical. I just swapped my 3.8L pump over to the 351 bracket off of a truck. Same with my ALT. (slight moding). I think all the AC pumps are the same to. Bolt size may be different as thy were with mine, but all holes lined right up.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
