351 Mustang
351 vs. 331
Old May 8, 2008 | 12:57 PM
aru_next's Avatar
aru_next
Default 351 vs. 331
here is the deal my buddy just got a 331 short block, he will have h/c/i. how will my 351 with a cam and intake run with it? he has an 85 gt, and we will both have 3.73's.
Old May 9, 2008 | 12:07 PM
S351R13's Avatar
S351R13
Default RE: 351 vs. 331
His should be quite a bit stronger. To keep up you'll need heads.
Old May 10, 2008 | 01:07 AM
militarymustang88gt's Avatar
militarymustang88gt
or a 125 shot.
Old May 12, 2008 | 11:25 AM
bighungrymatt's Avatar
bighungrymatt
depends what your h/c/i setup is
Old May 21, 2008 | 05:49 PM
mmm rice's Avatar
mmm rice
It depends on if the guy with the 331 chooses the right parts to make his combo work. Sema for you though.
But you still wont beat me
Old May 21, 2008 | 11:04 PM
86_Notch's Avatar
86_Notch
<-- 351, flat tappet 292 cam, dished pistons, windsor jrs, 373s, auto, 3500 stall, drag radials 11.70s ( went 11.90s with ported stock heads )
Old May 22, 2008 | 03:44 AM
w8less's Avatar
w8less
https://mustangforums.com/m_4205082/tm.htm
Old May 25, 2008 | 07:19 PM
aru_next's Avatar
aru_next
ORIGINAL: mmm rice
well if you do beat me Ill justmake mine faster! Im going to beat you, you bastard! lol
Old May 27, 2008 | 05:50 PM
aru_next's Avatar
aru_next
what would be a good time with the 351, cam, intake and slicks?
Old May 27, 2008 | 06:16 PM
BlessedHellride's Avatar
BlessedHellride
A 351 short block with the same time, money and supporting mods as the 331 will crush the infearior cid engine. No replacement for displacement!
If you are that worried about being out run, ****** the top end of that 351 and pull the hydrualic cam out, replace with a solid lift flat tappet, change the springs and stuff on the heads. Set the valves cold about .018" or so depending on who ground the cam, throw your heads on there with some very mild port work and you'd be laughing at him for months to come. I know a guy that went from a hydraulic flat tappet to a solid flat tappet cam and picked up just over a second off his E.T. and almost 6 mph in the quarter.
