351 Mustang
408W compression
Old Jun 18, 2008 | 11:01 PM
d_och23's Avatar
d_och23
Default 408W compression
I'm fixing to stroke my 351 to a 408 but I'm trying to keep the block on pump gas. Whats the most I can go on compression? Is it better to just buy a crankkit orbuys the parts individually?
Old Jun 18, 2008 | 11:23 PM
woodsy's Avatar
woodsy
Default RE: 408W compression
Depends on the chamber size of the head you will be using, but figuring a typical 58-60cc head and a dish around 22cc's will leave you around 10.5:1 depending on deck height and head gasket used. For ease, keep it at 10.5 or lower. Buy a kit as you wont know which crank will or will not use a 6.200 rod or a 6.250 rod or even a 6.125 rod and which piston will accomodate as well. Keep it simple, this is the whole point behind kits, they still need to be put together by a competent engine builder, these are not lego were playing with although people hear "kit" and think johnny and a bunch of sockets can wing it, till it blows up.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
