351 Mustang
cam advise
Old Jul 1, 2008 | 06:56 PM
ARYANW's Avatar
ARYANW
Default cam advise
whats the most lift a 74' 351w with stock heads take?
Old Jul 1, 2008 | 07:04 PM
w8less's Avatar
w8less
Default RE: cam advise
its not lift its the duration you need to worry about
Old Jul 2, 2008 | 05:55 PM
ARYANW's Avatar
ARYANW
well....what doyou recommend?
Old Jul 2, 2008 | 07:22 PM
Indy's Avatar
Indy
I've heard a handful of times that the biggest cam you can run on a 302 or 351w with stock heads and pistons is an E303 or equivalent. However, the best thing you can do is pick a camshaft, pull one of the cylinder heads and check valve to piston clearance. It's the smart thing to do in any cam swap anyways.
Indy
Old Jul 3, 2008 | 05:48 PM
ARYANW's Avatar
ARYANW
im lookin for good power thro about 1800-5600 is all and a real nice rough idle =) without head work yet.
Old Jul 3, 2008 | 06:46 PM
ARYANW's Avatar
ARYANW
would i be safe with
218int./224exh. at 050 duration,
262 int./270 exh. AdvertisedDuration,
0.493 int./0.500 exh. lift,
110 LobeSeparation
....i have barely any knowledge of cams lol
Old Jul 4, 2008 | 11:34 AM
Indy's Avatar
Indy
Won't be very rough, IMO. I've run a cam with 274deg ADV. duration, and people barely noticed. However, those specs probably fit right into the power band you're looking for.
Indy
Old Jul 4, 2008 | 11:36 AM
Indy's Avatar
Indy
Oh yeah... Should have no problem with valve-to-piston clearance with that camshaft and a .039" crush head gasket. But for the time it takes to be sure just check it when you get a cam.
Indy
Old Jul 4, 2008 | 04:41 PM
ARYANW's Avatar
ARYANW
what would give me the rough idle?
Old Jul 6, 2008 | 11:13 AM
Indy's Avatar
Indy
I think 284deg and up duration cams with 106-110 overlapis where the"good lump" starts, lol. But remember that those specswill change theoperating RPM of the cam. So you may not be able to fall into your desired RPM range exactly. Now, I'm now camshaft expert though.I would adviseyou to either research some off the shelf units on Crane or Comps, etc... websites(which give great descriptions of their product including"roughness" at idle) or call their tech support andexplain your combo and what you want to achieve.
Indy
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
