351 Mustang
351w build?????
Old Aug 3, 2008 | 09:46 PM
nkates866's Avatar
nkates866
Default 351w build?????
all right guys i need a little help and advise. i have a 94 gt that is getting a 351 put in it. now i got the motor from a 91 f350 pickup for free and im going to have a shop rebuild the bottom end. now my question would be what combo of internals, heads, fuel injectors. i all ready decided to run a efi spyder upper and lowerintake. but id like to see around 400 to 450 hp on motor and tuning alone. then eventually put a supercharger on it for the 550 to 600 range.
so my main question is what would you guys recomend me using to achive my hp goals.
Old Aug 8, 2008 | 11:32 PM
S351R13's Avatar
S351R13
Default RE: 351w build?????
The efi spyder intake is a high rpm or forserious superchargedapplications. It needs lots of rpms. You'll need good heads and astrong bottom end. If this i going to be a treet car you'll want to go with a TFS street or even a track heat intake. Remember with a supercharged motor a set of 42 lb injectors are really only good to about 540 rwhp. Then they end up have to work at over 100%. To see 400 hp on motor you'll need a good set of heads. TFS street heats or afr 205' or 225's that have been ported.
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
the5
Sep 19, 2015 06:13 PM
