351 Mustang
351 swap
Old Nov 12, 2008 | 04:05 PM
1994Cobradriver's Avatar
1994Cobradriver
Default 351 swap
i have a 1994 cobra and i was wondering if a 351 swap would work?
Can i fit the 351 with the 5.0 efi?
Old Dec 8, 2008 | 01:12 PM
COBRA1994's Avatar
COBRA1994
Default 351 TRANSPLANT
YES IT WILL WORK HAVE 392 STROKER IN MY 94 COBRA HOOD CLEARANCE IS ISSUE BUT COWL HOOD REMIDYS PROB. GOOD CHOICE IS CERVINIS IT IS WIDER THAN HARWOOD TO ACCOMIDATE FOR INTAKE TUBE IF U PLAN ON KEEPING FUE INJ.
Old Dec 19, 2008 | 12:43 AM
minnow81469's Avatar
minnow81469
Yeah but depending on the 351 you wont be able to hook up ac and other things i tried with a 1979 351w in my 95 and the acessorys couldnt bolt up so i pulled the 351w back out and im stuck with the engine and tranny and you can keep it efi everything else bolts up except the accessorys but clearance wasnt a problem for me with the stock hood
Old Dec 19, 2008 | 02:17 AM
jtmustang's Avatar
jtmustang
^^u need the accessory brackets for a 351.....
Old Dec 19, 2008 | 10:16 PM
FORD TOUGH's Avatar
FORD TOUGH
I think latemodel restoration supply and probably a lot of other people have the brackets.
Old Dec 19, 2008 | 10:45 PM
S351R13's Avatar
S351R13
If the 351w was installed in a 94-95 you use 94-95 brackets. They bolt right up. 79-93 Mustangs, if you use the stock front accessories you have to by a swap bracket from FRPP. 94-95 brackets bolt to the cylinder head, thats why there is no issue when swapping them.
Old Dec 27, 2008 | 06:39 PM
minnow81469
Yeah but how do you bolt up the accessorys from a v belt to 6 rib thats the problem i ran into unless you can change all pulleys but i couldnt find all the stuff to do it also for the computer do you have to switch the comp or with the 5.0 computer run fine with the 351 w in it(is programming required)?
Old Dec 27, 2008 | 08:49 PM
dudeboy's Avatar
dudeboy
Programming the stock ecu shouldn't be required... but I would recommend it...
I cleared the stock hood in my 90GT with Energy Suspension motor mounts, and trimming my upper intake about .700". I used a Lightning lower and comp cams box upper intake.
There was still a very slight run on the insulation mat from the breather tube that comes off the top of the TB.
jason
Old Dec 28, 2008 | 11:19 AM
S351R13's Avatar
S351R13
You have to change all the pullies and the front cover and waterpump. Doing these swaps that is a corner you can't cut.
Old Dec 28, 2008 | 10:31 PM
minnow81469
Where do you find the other pullies though i would stick that engine back in if i could get it all to work i still want ac since the car is a street car
