351 Mustang
head selection
Old Jan 18, 2009 | 01:02 PM
91foxbody351's Avatar
91foxbody351
Default head selection
1995 5.8 roller block, kept the stock crank, forged h beam rods, forged 12:1 pistons, what heads do you guys recommend
Old Jan 18, 2009 | 07:49 PM
BlessedHellride's Avatar
BlessedHellride
If it were me, I'd throw on a set of AFR 205's or some High Ports from Trick Flow. The 205's are probably a little cheaper. Do you already have a cam for this short block or no? If you do have one, you might want to get ahold of a couple of cam grinders and see what they would recommend for your engine. This will give you optimum performance from your set up. Not that OTS cam and heads doesn't make decent power, they do, you will just see more from a custom cam and all.
Old Jan 19, 2009 | 08:07 AM
TrickFlowTech's Avatar
TrickFlowTech
Banned
What size cam? What rear end gear? What is the intented use of the car? Automatic or 5 speed?
Old Jan 19, 2009 | 08:21 AM
BlessedHellride
^^^ See, I told you they would chime in. I'm sure it's better to listen to one of these guys rather than some "average joe" like me and others on here.
BlessedHellride
Does Trick Flow offer any discounts for forum members?
Old Jan 19, 2009 | 08:32 AM
TrickFlowTech
Banned
Nope not yet anyway. Sorry.
Old Jan 19, 2009 | 02:18 PM
91foxbody351
im running a c4 tranny, its got 3.73 gears in it right now, 28x10.5 slick and will spray a 100 shot, no cam yet, and i will use the car for street and strip, i have an 850 holley for it, and a victor jr intake manifold, thanks for the suggestions they are helpful
Old Jan 19, 2009 | 04:13 PM
jtmustang's Avatar
jtmustang
easiest and best thing to do is contact jay at www.camshaftinnovations.com and fill out a buildsheet and he will get you what u want and will probably exceed your expectations..
Old Jan 23, 2009 | 07:09 PM
Liquid_02's Avatar
Liquid_02
Is it a stroker? Is it going to be boosted. Chances are the victor jr.'s will work very well for your app. They're cheaper, not ported, but who cares? You won't need the porting anyway. Porting is only worth about 30cfm, that chances are your engine won't need, and about $500 less than the others just because they're not ported. Jr.s are very good heads.
Old Jan 25, 2009 | 08:22 AM
91foxbody351
thanks for all the recomendations
