2.3l to 5.8
Ok so i finally picked up a car to put the 351 into. so the specs are
1990 mustang LX 5spd 2.3l fi
Donor vehicle is:
1982 ford f-250 carb 351w with a 4spd standard..
So i've read up on alot of swaps similiar but can anyone tell me any hints or tricks to this swap, i know the regular oilpan oilfeed, cowl hood, rear end.
What i was really curious about was the harmonic balancer, since i have a full donor engine will i need to worry about it? And also is someone had knowledge on fuel delivery, becuase i read somewhere you need a lower pressured fuel pump(about 15 psi) just wondering if this was true. so any help or hints would be appreciated!
Donor vehicle is:
if you use the harmonic balancer that came with the donor engine, it will work just fine. as for the fuel pump, the 351 should have a mechanical pump already installed. just take the fuel pump out of the gas tank of the stang and install a rubber tube to lengthen the pickup. then use your mechanical pump on the 351. dont forget you will need headers for the 351 swap.
