351 Mustang
complete suspension overhaul.
Old Apr 16, 2009 | 07:27 AM
TopNotch89's Avatar
TopNotch89
Default complete suspension overhaul.
i was curious whether anyone knows if there is a complete suspension kit you can buy, with everything...or close to everything that would be good to have a 351 notch hook to the street. id probably be running weld draglites with some slicks or something. but i know suspension is key. also, a 8.8in rear end can be mated with a 351 correct?
Old Apr 16, 2009 | 08:14 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
yes and MM would be your best bet for complete suspension packages.
Old Apr 16, 2009 | 08:51 AM
TopNotch89's Avatar
TopNotch89
MM? do they have a website?
Old Apr 16, 2009 | 09:49 AM
FivePointOhh
in limbo
http://www.maximummotorsports.com/
they sure do, they make it very conveniant to get your suspension done all in one shot.
Old Apr 16, 2009 | 10:10 AM
TopNotch89's Avatar
TopNotch89
thanks man, im going to check it out right now....what would be recommended to get for suspension just doing everything? or the basics?
Old Apr 16, 2009 | 10:25 AM
FivePointOhh
in limbo
at the minimum i would do the basics. shocks/struts and springs. what are your goals? budget?
Old Apr 16, 2009 | 10:36 AM
TopNotch89's Avatar
TopNotch89
well come this time next year i want to have a built 351 to put in....i should be getting the motor this week, and i know the 351 is a torque monster and with the right rebuild can be a beast...and i know im going to need the suspension to hold everything down...id probably go with weld draglites or something and a street slick or something
Old Apr 16, 2009 | 10:44 AM
FivePointOhh
in limbo
in that case i'd do shocks, struts, springs, adj. upper and lower control arms, subframe connectors.
you can also, if you wanna go all out, go with a tube k member to lose the extra weight of the 351 and go coilover on the front.
Old Apr 16, 2009 | 11:06 AM
grabbem88's Avatar
grabbem88
team z motorsports...better quality better customer service,and for the prices team z is top notch for your notch
Old Apr 16, 2009 | 11:09 AM
grabbem88's Avatar
grabbem88
http://www.teamzmotorsports.net/
