351 Mustang
could use some help
Old Nov 15, 2009 | 10:55 PM
5.8 notch's Avatar
5.8 notch
Default could use some help
I have tried to find answers or suggestions from several sources with no luck,I currently have a 393 windsor motor with TFS high port cylinder heads and a TFS r lower intake with the R long runner upper,comp cams hydraulic roller 274 and 288 at .006 ( can give you full specs if required) Im running 80lbs injectors and a 75 mm throttle body and kooks 1 7/8 long tube headers with a tko 600 and a snow water/meth injection.Compression is 8.5 to 1 eagle H beam rods,eagle crank,main girdle and malhe pistons and 1.6 comp cams roller rockers.
I also have a vortech V1 T-trim race m supercharger installed,now mind you the car is all fresh and motor has yet to be fired,I currently have a 77 tooth crank and a 30 tooth blower pulley with the previous guy said he was pushing about 18lbs of boost on his 331.
I would like to be in the safe pump gas area for street driving and would like to know what amount of boost would be appropriate for my application for for it to be safe and not required race gas.Also would like to know what pulleys I could run to get me into the 10 to 12 lbs boost range I would like to stay with my cog set up if possible and would like to know what pulleys I would be required to run to get into this boost area.I also realize that its impossible to determine exact numbers based on this info but I would like a ballpark number to start with.
thanks
Old Nov 16, 2009 | 12:07 AM
5.8 notch's Avatar
5.8 notch
ok so no ones interested in offering any advice or input here?
Old Nov 16, 2009 | 10:22 AM
5.8 notch's Avatar
5.8 notch
ok then I guess I will look elsewhere for advice and input
Old Nov 16, 2009 | 02:27 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Don't stop so quick, not alot of guys in the 5.0 section come into the 351 area. You should contact vortech about the pulley question and I am sure they might be able to help you with the gas issue too. That sounds like one hell of a nasty setup you will have going. Get some pics and vids up when its going!! You can probably get away with posting it in the regular 5.0 gen discussion and tech areas if needed next time.
Old Nov 16, 2009 | 11:20 PM
5.8 notch's Avatar
5.8 notch
tried vortech they really arnt much help they just tell you that they cant give accurate boost level because each car and set up is different thought some guys with similar set ups would chime in
Old Nov 17, 2009 | 12:42 AM
Slow5o's Avatar
Slow5o
wow hard to believe the guys at vortec wasnt much help as they should make a pully for 10-12 psi i would reccomend calling this number they build some pretty nasty stuff and would be best to answer ur question
the name is powered by ford and .
there number is 407-863-3673 gave me a great deal of insight on my old 5.0
