351 Mustang
Headers Help again...
Old Dec 26, 2009 | 09:35 PM
nissan owner's Avatar
nissan owner
Default Headers Help again...
So I have a 351w with a C4 I am officially done putting the motor together. I have Vic. Jr Heads on it I know the exhaust port is raised but I wanted to know if the BBK shorty headers would work....Since the exhaust port is raised I was looking for the Kooks but my budget doesn't allow it and I want to get this car on the road already. Any help would be greatly appreciated?
These are the headers I am looking at
http://www.summitracing.com/parts/BBK-1511/
Come on guys help a fellow 351w Mustang owner out
Old Dec 27, 2009 | 10:14 AM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
for like $50 more you could get a set of MAC 1 3/4" longtubes for a 351W swap...
Old Dec 27, 2009 | 05:29 PM
nissan owner
Mac says they won't clear because of the exhaust ports being raised on the heads.
Old Dec 27, 2009 | 10:25 PM
sn95_331_GT_ yellow
they're lying.
the ports on those heads are raised like 1/8".
thats about MAYBE 1/16" total over stock. theyll be fine unless youre running like 1/2" + raised ports.
they're just covering their asses.
Old Dec 27, 2009 | 10:38 PM
nissan owner
they're lying.
You think that with the convertable engine mounts lowering it about .5 inch that would fix it, or am I way off?
Old Dec 27, 2009 | 10:44 PM
nissan owner
because if the longtubes work from MAC i'll just get them
Old Dec 28, 2009 | 11:27 AM
sn95_331_GT_ yellow
DO NOT use the vert engine mounts. there's a reason Ford engineered the driveline angles the way they did. DONT change it.
and the height of the engine in the car is irrelevant, its the actual height of the ports on the heads.
either way, 1/8" is not going to result in catastrophic rubbing on the floorboard and ruin everything.
just get the MAC ones.
remember longtube > shorty.
not even a comparison.
Old Dec 31, 2009 | 08:45 PM
nissan owner
ordered...we will see what happens
Old Jan 3, 2010 | 10:51 AM
cccharleston's Avatar
cccharleston
They will work. I have to put the passenger side on with the engine lifted off the mounts a couple of inches and I clearanced the floor pan where it meets the fire wall.
Old Jan 4, 2010 | 09:16 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
1. Vert mounts are not going to hurt anything. Poly mounts are designed after the vert mounts and I have NEVER heard of any problems because of this.
2. The height of the engine does matter. The higher the engine sits, the higher the collector of the header will sit.
