351 Mustang
NEED HELP PLEASE!!!
Old Mar 11, 2010 | 01:26 PM
Flight302's Avatar
Flight302
Default NEED HELP PLEASE!!!
A few things....I just dropped in a 351w in my foxbody and and i got a 650 cfm carb on it and my stock throttle cable is waaaay to long for the carb setup does anyone know where i can get one for a carb setup? or do i need to rely on carbed mustang at the junkyard? Another thing....I got a new fuel pump for it. Its a 190 lph universal fuel pump and it sits outside the tank rather than my stock one sitting in tank. What do i need for that to work?????? Do I need a new sending unit? Is there like a kit I can buy?? Also, the fuel lines have the quick disconnect fittings should i just cut them off???? or replace all the fuel lines???
Idk if im the only one with these problems I cant find anyone else on here so i guess its not a big deal
Any help would be greatly appreciated THANKS!!!!!
Old Mar 17, 2010 | 09:00 PM
ryppdlm's Avatar
ryppdlm
First of all you need to call Aeromotive for information on building the fuel delivery system for your car. Second, Fragola Performance Products makes the fittings for the stock fuel line to flexible fuel line, so please do not cut those off. As for the throttle cable continue your search of the internet for a company who makes one (should be several aftermarket companies making this item as a efi to carb switch is somewhat common).
Old Mar 18, 2010 | 10:06 AM
wildcobrar's Avatar
wildcobrar
Early carbed Mustangs and Thunderbirds, Cougars, and Lincolns in the Fox Platform years 1985 or older will get you the cable you need. Even in V6 form. My throttle cable on my 1990 Mustang(5.8 Carbed) was snagged from an 83 TBird V6 car.
Joe
Old Mar 19, 2010 | 11:31 PM
Flight302's Avatar
Flight302
YESSS!! thankyou guys got everything i needed!
