351 Mustang
99 IRS in a 95GT with a 5.8L Help
Old 09-01-2010, 09:52 PM
Kozz167
Kozz167's Avatar
Smile 99 IRS in a 95GT with a 5.8L Help
I am a left right driver more than the strip (though I do love the strip, so I found a 99 IRS for $450 with new half axles, but its the 28 spline. I know My handling will be alot better, but is it worth it with only the 28 spline or should I hold out and fined a 01-04 IRS with the 31 sline to handle my new engine (5.8L) and the posible power she could or will have?
Kozz167 is offline
Old 09-08-2010, 03:37 PM
.boB
.boB's Avatar
I'm running close to 600hp through a 28 spline IRS diff. Parts are 4 years old, and no problems. But, my car is 1,000# lighter than yours (give or take). I run it hard on the road course pretty often.
As long as you're spending your time on the road course or cone dodging, I don't think you'll have a problem. If you're worried about it, contact Raxles for their high performance version.
.boB is offline
Old 09-08-2010, 10:26 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
03/04 has the 31 spline, 01 is still the 28 BTW
my 331 is getting the 31's but only because i got an 03...
sn95_331_GT_ yellow is offline
Old 10-23-2010, 03:04 PM
S351R13
S351R13's Avatar
You won't see much benefit with the IRS. I tried it before on the road course and swapped back. Your spring and shock combo make more of a difference with a Mustang.
S351R13 is offline
Old 10-23-2010, 05:40 PM
sn95_331_GT_ yellow
in it more for the uniqueness than the "performance" upgrade.
if i wanted the end all id get a panhard bar/torque arm set up and show every other IRS car (Vette, Porsche, etc) nothing but tail lights.
having IRS is only something ive ever seen once before on a round (94-98) SN95. seen it once on a fox as well. seen it about 8000 times on the New Edge Mach 1's though...
so i want it just to be different.
Old 10-23-2010, 06:38 PM
.boB
.boB's Avatar
The improvement in ride quality is amazing. My '08 Mustang had a harsher (stock) ride than my Cobra with IRS. I thought Ford really made a mistake in using a solid axle.
.boB is offline
ChampInSD
10-02-2015 04:55 AM
LiquidDrink
09-29-2015 10:06 AM
09-17-2015 07:57 PM
09-16-2015 07:53 PM
09-08-2015 11:50 AM
Quick Reply: 99 IRS in a 95GT with a 5.8L Help
