351 Mustang
Fuel Pressure Issues
Old Aug 9, 2011 | 05:17 PM
87Stallion's Avatar
87Stallion
Default Fuel Pressure Issues
Hi guys. Im having a weird issue with fuel pressure.
Heres the scoop
Im running a carbed engine.
New edelbrock 1792 pump
New quickfuel regulator
New fuel pressure guage mounted to fuel rail
New 3/8 line from tank to carb
All this stuff is new. Pressure randomly goes from 5-10 psi.
Ill set it to 6 psi then a hour later it goes to anywhere from 5-10
I tried a diff regulator and another new guage same issue.
Could this be a voltage drop issue at the pump?
I wired it to the factory EFI wires that connected to the stock EFI pump. So I am using the factory relay.
Any ideas?
Old Aug 16, 2011 | 09:33 AM
393Bird's Avatar
393Bird
What is the part number of the regulator? Most of there regulators are return type, and regulate by sendung excess fuel back to the tank via a return line. If you only have 1 fuel line from the tank to the carb, you need one of the older style dead head regulators.
Oct 26, 2015 05:01 PM
StalkerGT
Sep 25, 2015 02:41 PM
TfcCDR
Sep 14, 2015 12:08 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
zanemoseley
Sep 6, 2015 12:58 PM
