Driveshafts
Just wanted to get an idea on what those of you think of the following.
http://www.exoticperformanceplus.com....html?item=609
"This rotational weight reduction alone is responsible for gains of 15+ rear wheel horsepower. "
Just so you know, the page you posted has the price for the pinon yoke. You can also build your own driveshaft by using a Ford Racing aluminum driveshaft for a 4x4 Ranger shortened 9" and a 03-04 Cobra pinion flange. I plan to use these parts to build my own.
The stang shop I use has recommended an aluminium one piece shaft and this would probably be even better. I am holding off until they have done one and can put it on their dyno to determine the hp gain. I don't want to be the first to drop 1K+ for this upgrade.
You can pick up the Ford Racing driveshaft and pinion flange from any FRPP dealer. The part numbers are:
Driveshaft: M-4602-R
Pinion flange: M-4851-B
You are looking at about $240 for the driveshaft and $30 for the pinion flange plus about $150 to have the driveshaft shortened and balanced. ~ $420 is a whole lot better than $700 to me. Plus I wouldn't worry about the aluminum Ranger shaft up to about 600rwhp.
That's the one I'm going with - JPC Racing. In addition to reducing the rotational weight, I'm getting the aluminum driveshaft because it's stronger. I don't figure that stock 2 piece is going to hold up to too much punishment. -Joe
