Is it worth the difference?
Old Aug 1, 2006 | 12:25 PM
05 Cayuse's Avatar
05 Cayuse
Default Is it worth the difference?
I'm going ahead with the install of the 3.73 gears, and need to decided on a LSD. Between T-Lok and TrueTrac, is it worth the 2.5 times the cost difference for TrueTrac? What do you guys think?
Old Aug 1, 2006 | 12:38 PM
hamidlmt's Avatar
hamidlmt
I ♥ Acer
Default RE: Is it worth the difference?
For most applications, the t-lok seems to be holding out quite well... guys like Scrming are showing it can handle loads of torque. But, eventually, it will have to be rebuilt (same with my Auburn). The TrueTrac will hold up until it just goes all together. It's also the strongest LSD out there, as far as I know... if you're still planning on forced induction (X-charger, right?)... the TrueTrac might be the way to go.
So, no clear cut answer for ya... but those are a few of the pros and cons of each. I was going to go with a t-lok until my shop cut me a good deal on the Auburn.
Old Aug 1, 2006 | 12:41 PM
BlueStang6's Avatar
BlueStang6
I also own a 2001 GT manual with almost 100K miles on my t-loc - its my daily driver and I haven't had a problem (or whine) in all that time.
Old Aug 1, 2006 | 01:26 PM
lrgnation's Avatar
lrgnation
whats the downside of just welding the gears?
Old Aug 1, 2006 | 03:41 PM
GrayPony's Avatar
GrayPony
ORIGINAL: lrgnation
Turning corners
Old Aug 1, 2006 | 11:53 PM
05 Cayuse's Avatar
05 Cayuse
Thanks for the input guys. I think I'll pass on the welding job though.
Old Aug 2, 2006 | 01:30 AM
mustangman02232's Avatar
mustangman02232
ORIGINAL: BlueStang6
completely different unit, GTs are 8.8, 6ers are 7.5, the 7.5 is originally designed to come from the factory in the ranger/bronco 2, a detroit true trac has no clutches to wear out, hence it will last a longer time,
Old Aug 2, 2006 | 10:35 AM
rygenstormlocke's Avatar
rygenstormlocke
ORIGINAL: mustangman02232
My understanding is that the spider gear design for the tlok that goes in the 7.5 is the same as the 8.8, only smaller. Correct me if I am wrong here.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
mrappe
Sep 26, 2015 10:16 AM
