Rev Limiter?
Old Aug 6, 2006 | 03:02 AM
blackfoot's Avatar
blackfoot
Default RE: Rev Limiter?
an automatic wont over rev it will just shift till the final gear.. then it will overrev lol..
unless you got a tune and yyou can controll shift points
the only way i can see if a miss shift blows an enigne is if they went from 4th to 1st or something... if they could even get it into first..
if not you may blow the teeth off a gear on a mis-shift
Old Aug 6, 2006 | 09:22 AM
TNT1968's Avatar
TNT1968
On a manual tranny during powershifting a missed shift will smoke the engine when it's overrevved. On an automatic if you manage to snap an axle or the driveshaft you could smoke the engine. Also an accidental drop into neutral under load could do damage.
Old Aug 6, 2006 | 11:55 PM
blackfoot's Avatar
blackfoot
true if you threw it into 2nd after you overreved 3rd.. that would happen..
Old Aug 24, 2006 | 06:59 PM
The_Third's Avatar
The_Third
how do you go about moving the limit?
Edit: and how would you go about removing it completely, and does this void the warranty?
Old Aug 24, 2006 | 09:22 PM
TNT1968's Avatar
TNT1968
You have to have an XCalII or equivalent to change the rev limit.
Nick Oliver
Oct 17, 2018 04:22 AM
firehorse02
Nov 16, 2015 11:28 AM
wraith777
Sep 28, 2015 10:49 AM
treesloth
Sep 28, 2015 07:03 AM
Offendant
Sep 23, 2015 07:21 PM
