Whats the diff?
Old Aug 21, 2006 | 02:03 PM
beaustang's Avatar
beaustang
Default Whats the diff?
I've seen Detroit TruTrack rear ends and Detroit Lockers; whats the diff in these diff's?
Old Aug 21, 2006 | 02:37 PM
fazm's Avatar
fazm
Default RE: Whats the diff?
lockers are for offroading applications mostly. Work like any other locker out there. The truetrac is a LSD differential.
Old Aug 21, 2006 | 02:58 PM
beaustang's Avatar
beaustang
Thank you.
ORIGINAL: fazm
Old Aug 21, 2006 | 04:25 PM
davelong667's Avatar
davelong667
I ♥ Acer
Yeah alot of times those lockers are pneumatically operated, they can be locked by using air pressure into a tube that goes into the differential. inside the differential is an air operated device that locks and unlocks the wheels for traction. and LSD is a limited slip differential also for better traction, but you would not want to "lock" your wheels on the street...lol you have a hell of a time turning a corner...lol probably would break your drivetrain.
Old Aug 21, 2006 | 06:03 PM
petepete's Avatar
petepete
Since were on the subject. Is there a big difference between the Auburn limited slip and the traction lock limited slip? or is the auburn just stronger
Old Aug 21, 2006 | 06:12 PM
fazm's Avatar
fazm
just stronger. it uses friction clutch packs just like the tlok though
Old Aug 21, 2006 | 06:18 PM
petepete's Avatar
petepete
So the only upside to it is less rebuilding of it. One question about the detroit. I heard it makes it affects cornering? What is your experience with it. Im thinking im gonna get rid of this t-lock if its worth it
Old Aug 21, 2006 | 07:42 PM
blackfoot's Avatar
blackfoot
the lockers aka posi.. or positive traction.. both wheels spin all the time.. basically your *** end will skip across the road while turning , unless your on the gas abit.. then youll be spinning out on your corners.. LSD, allows for rates of change in your rear end , like taking a corner the inner tire will slow down, and the outer will speed up.. , but in a straight line both tires will spin in sync
Old Aug 22, 2006 | 01:38 AM
mustangman02232's Avatar
mustangman02232
ORIGINAL: fazm
lockers are for the strip, spools are for offroading applications mostly
and yes it is worth it, detroit true tracs have no clutches to wear out unlike the t-lok, which is not a preformacne part
Old Aug 22, 2006 | 01:39 AM
mustangman02232
ORIGINAL: blackfoot
a locker locks the rear wheels together, an LSD aka t-lok, posi, sure grip w.e makes both wheels turn until you go into a corner and allow them to spin at different rates
