driveshaft question
how much can the stock driveshaft take? with that what would be a good oen to swap to? would a GT one fit and be stronger? or should buy an aftermarket one? is it really crucial for a N/a stang to upgrade this? i occasionaly have hit up to 110 but very rare. any input is appreciated.
and on that note how difficult is it to do? could i do it myself? or does it have to be installed. thank you |
RE: driveshaft question
ORIGINAL: S1ckStang how much can the stock driveshaft take? with that what would be a good oen to swap to? would a GT one fit and be stronger? or should buy an aftermarket one? is it really crucial for a N/a stang to upgrade this? i occasionaly have hit up to 110 but very rare. any input is appreciated. and on that note how difficult is it to do? could i do it myself? or does it have to be installed. thank you |
ok thank you i have been reading alot about the driveshafts breaking and got worried but no one mentioned the year i have a 2006 that is an end of the model year. thank you for your help
the newer oneswith the clips what can they take? how much better are they? |
It's heavy and overly complicated for a driveshaft but it'shighly unlikely to break especially the way your driving habits are.
What happened (in a very few cases) is that at high speed/high rpm, the lack of retaining pins was causing the u-joint to slip out due to vibration. When that happened the driveshaft end dropped and hit the ground at high rpm causing it to break. |
