niosy transmission
Hi guys/gals,
need some advise here: my newly bought '07 v6 manual transmission makes weird clinking noises, particularly when engaging the clutch on 1st and 2nd gears, feels almost like something is loose at the engine' end of the driveshaft. Another issue - when releasing the clutch in neutral, I heara low grinding noise (non-lubricatedbearing?). When the clutch is engaged (pedal down) the sound disappears. I had the car for a little over one week nowand haven't noticed it at first. Took it backto the dealer who sold it, they test-drove it and said it is normal :-((. Does anybody have similar problems here? My paranoia is growing and I am starting to feel the buyer's remorse. Thx |
RE: niosy transmission
our mustangs have noisy transmissions.. my advice would be to insulate the shifter housing to quiet it down a bit. if your trans goes, it's covered by warranty, so don't worry about it
My transmission is very noisy as well, and it makes a grinding noise in 4th gear at low RPMs. 2007. 2500 miles.
I dont know about the auto tranny's but the manual ones make alot of noise. From what I understand it is all related to the driveshaft. As alot of us know, the v6 driveshaft is crap, there are several threads documenting this. A few have even failed at high speed.
you can pick up a good aftermarket DS for about $600. I know of a good deal on the Powerhouse Driveshaft. PM me if you are interested. |
Other than reliability, is there any performance gain from switching to an aftermarket DS?
Everyone will tell you these are our transmissions...they are known for being noisy!
Some things that may solve it: -New shifter (Hurst or Steeda). -New driveshaft (Dennys) -Turn up your music ;) |
ORIGINAL: JochenHeiden Other than reliability, is there any performance gain from switching to an aftermarket DS? |
My car does the same exact thing
Mine also from day one. Ford does say it is normal. There is a fix, replace tranny fluid with Royal Purple synchromax. Cost about 30bux. It will cut noise way down with smoother shifts...
people report a 1-2mpg gain when they switch to an aluminum driveshaft... the less mass you have to spin, the easier it is for the engine to transfer power to the wheels.. you don't make more power, you just lose less.. it's like swapping in a lightweight flywheel.. less mass to put into motion
