engine mounts
Old May 4, 2007 | 11:58 PM
DelStang86's Avatar
DelStang86
Default engine mounts
what do you think? I was looking into them and I was wondering why they think you'd need to take it to a mechanic for the install... you just support the engine with jack/2x4 and replace the mounts, right?
Old May 7, 2007 | 11:48 AM
DelStang86's Avatar
DelStang86
Default RE: engine mounts
anyone?
Old May 7, 2007 | 12:59 PM
Jerseyfury2's Avatar
Jerseyfury2
i mean sounds feasible the way you're talking but just don't drop the motor lol
Old May 7, 2007 | 05:31 PM
tedBalog's Avatar
tedBalog
I would do it with a cherry picker and some support..
Old May 7, 2007 | 11:18 PM
DelStang86's Avatar
DelStang86
yeah... i swapped the motor mounts on my last car... and after taking a look, thought it couldnt be too complicated... i thought i'd just, you know, shove some leaves underneath for support.
jk.
Old May 9, 2007 | 11:24 AM
28HopUp's Avatar
28HopUp
MF Administrator
Although I have not looked at my own motor mounts as a reference, you should be able to unbolt them and jack up the motor enough to remove and replace. Just make sure the hood is open when you jack up the engine! The trans mount is also a good thing to replace at the same time, as it will tighten up the drivetrain to the car and help minimize the binding flex that can occur, since the shifter is attached to the body and not the drivetrain.
Old May 9, 2007 | 03:37 PM
DelStang86's Avatar
DelStang86
thanks for the advice guys
mtgldr
Feb 3, 2024 09:00 PM
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 1, 2015 08:16 PM
