Transmission help please!
Old Mar 16, 2008 | 10:44 PM
sliek0722's Avatar
sliek0722
Default Transmission help please!
Definitely have a problem with second gear when I downshift. I'm real gentle on my clutch and I watched it today, I downshifted to second gear, let off the clutch and halfway through the engine compressing to higher RPMS, it pops out of gear and starts grinding. It happens even more when I'm coasting in neutral and then I'm at a speed where I need to engage second gear (such as a light turning green) press the clutch, put it in second, halfway through engaging the gear, it pops out and starts grinding.
It doesn't pop out of gear when I'm engaged in second gear and driving along. It only pops out when I downshift or if I upshift fast. If I'm gentle when I upshift it's fine. It doesn't even work if I hold the shifter in place when I downshift because it will still pop out and start grinding.
Does this sound like a need-a-new-trans issue or maybe i can get off with an inexpensive fix?
Old Mar 16, 2008 | 11:27 PM
GrayPony's Avatar
GrayPony
Default RE: Transmission help please!
Sounds like a shot syncro
Old Mar 17, 2008 | 12:47 PM
05MustangSally's Avatar
05MustangSally
My car did this brand new [:@] A new shifter would also help because ours suck!
Old Mar 17, 2008 | 03:54 PM
sliek0722's Avatar
sliek0722
Ford service told me on the phone it sounds like a shot syncro too. I have no more warranty. Estimated repair cost $1800.
Old Mar 18, 2008 | 12:56 PM
05MustangSally
If you're a gear head, it isn't that hard to replace yourself. But you'd have better luck shopping around for a shop to do it for way less! Pullinga tranny should only take a few hours. You'd want to find a shop that has a low hourly rate. Ford is way overpriced!
ORIGINAL: sliek0722
Old Mar 18, 2008 | 12:59 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
The last time I put a tranny in an old Pontiac Bonneville, I feel asleep under the car because it was taking too long and I was doing it alone LOL
Old Mar 19, 2008 | 12:39 PM
05MustangSally
Yikes lol! Help is always best! Helped pull a Honda tranny most recently to change a clutch. Took about 10 hours including pulling, replacing, trips to the store, lunch and dinner breaks and putting it all back together. Also did a 76 Blazer swap (auto to manual) uncluding replacing the transfer case from a constant 4wd to 2wd & 4wd. That took a whole weekend. Trying to do tasks like this alone is not the best, safest choice.
ORIGINAL: ODDYSEY
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
