pypes x-pipe question
Old Apr 2, 2008 | 12:15 AM
chrispcola's Avatar
chrispcola
Default pypes x-pipe question
I was l ooking over 68XR7's post on installing a Ford Racing GT x-pipe to his V6. I know cutting is required and saw that he welded it to the downpipe. Anyone know anything about Pype's xfm44 x-pipe made for the V6s. I realize welding is really best, but is welding required for that particular pipe? I want to be able to do most of the work and if I have to, temporarily clamp it to take it to a shop to weld in place....If I can go without welding, it would be ideal...
Old Apr 2, 2008 | 07:38 AM
07 Stang's Avatar
07 Stang
Default RE: pypes x-pipe question
The problem I have found with Pype's is their clamps aren't made very well. If you can purchase another OEM Ford clamp, then you won't have to weld them. Now I did get my shop to do a tack weldfor piece of mind. I haven't had any problems since.
Old Apr 2, 2008 | 10:16 AM
chrispcola's Avatar
chrispcola
Cool, thanks for the info. So it did slide over/into the downpipe without any issues (no gaps)? I'd definitely get them welded eventually. I just want to be able to do most of the work myself. I know I could pay a shop to do it, but I would just get more satisfaction of out of it...
Old Apr 2, 2008 | 10:46 AM
68XR7's Avatar
68XR7
I understand that you want to do as much of the work as you can, and there are people around here that prefer to have their system clamped rather than welded, usually for ease of dissasembly. I much prefer the welded system. I mean, when you read some of the trouble that people have when they start changing these exhaust systems, it gets a little scary. I have never had any kind of trouble with mine. No clunks, rattles, drones, no nuthin'. I believe that the reason for this is: A. I used Only parts that were made BY FORD for the Mustang. B. I had a qualified shop do the install. The technician checked EVERYTHING very carefully before the final welding. Also remember, if you do have to remove the exhaust system for whatever reason, you can cut it carefully and then use your clamps when you re-assemble.
Old Apr 2, 2008 | 03:23 PM
07 Stang's Avatar
07 Stang
ORIGINAL: chrispcola
From what the guys said at the shop, the x-pipe and mid pipe fit like a glove. The only issue was getting the muffler on the driver's side to hang right.
I do think mine hang a little low, but I have gotten use to it and why mess with something that's not giving me any problems.....like rattles and such.
Old Apr 5, 2008 | 12:24 PM
chrispcola's Avatar
chrispcola
ORIGINAL: 07 Stang
Curious, I've been reading other peopel comment on the pypes clamps as well. Are they band clamps or u-clamps?
Old Apr 6, 2008 | 01:01 PM
kdrshocker's Avatar
kdrshocker
i have the pypes true dual setup. i installed it myself a while back.. everything fit alright exceptfor the drivers side muffler. it was hanging down and crooked. i ended up taking it to a shop backhome and the took all the clamps off and welded everything up. they had to cut one of the hangers on the drivers side muffler and reposition it about an inch lower just to get it in the right spot.
Old Apr 15, 2008 | 08:45 PM
shb5007's Avatar
shb5007
I am about to get a pypes x, welded in.
Old May 3, 2008 | 12:55 PM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
the kit comes with band clamps, junk. i saws-alled the h-pipe from the cats, had to get adapter fitings from the stock pipe to the x-pipe, slide it into the transmission mount hanger locations, and used FOUR band clamps to get it right... the rest of the system is welded in safely
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
