Weird Overdrive Problem
Old May 20, 2008 | 05:59 PM
bobs184's Avatar
bobs184
Default RE: Weird Overdrive Problem
I wish some of you could have been there today to explain this to Ford's service people because they looked at me like I was crazy.
I am going to go to an indepent shop tomorrow to explain the entire issue once more (which only seems to be getting worse) and ask them to visibly check each spark plug because this all may have resulted from my getting them changed. Although that doesn't make sense either.
This is the Flowmaster I have: exactly what I should have bought because it's model specific.
I thought Ford was insane today to tell me that I had to go back to stock exhaust to fix this problem.
http://store.summitracing.com/partde...p;autoview=sku
Old May 21, 2008 | 02:35 PM
mustangman02232's Avatar
mustangman02232
if you have that with one single 2.5" exhuast there is no way it is due to no backpreasure, in fact with a chokemaster, you probably have as much back preasure as stock, i have dual 2.5 on mine with LTs and it did nothing but help
try
-fuel filter
-TPS sensor
-plugs gaped wrong/new plugs/wires
Old May 27, 2008 | 02:39 PM
bobs184's Avatar
bobs184
Got it fixed. Crack in one of the spark plugs and all is back to normal. Power and sound are back, and acceleration is back to normal.
Old May 27, 2008 | 05:51 PM
John1A's Avatar
John1A
Thank you for letting us know. Interesting. If I get trouble again I'll be changing my spark plugs.
Old Jun 7, 2008 | 12:40 PM
John1A's Avatar
John1A
bobs184: Is your problem still fixed now you've swapped your spark plugs?
Mine's started to do it again, its like its going into overdrive far too soon at ~30-40mph. Only when car warmed up.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
MasterLanMan
Sep 13, 2015 08:21 PM
