3.73 install guide
Old Jun 25, 2008 | 09:27 AM
ruprect108's Avatar
ruprect108
Default 3.73 install guide
Are there any install guides for gears I could not find any. Also for putting in the T-lok I am thinking of doing both of these myself with a little help. Thanks
Old Jun 25, 2008 | 12:44 PM
Sancho805's Avatar
Sancho805
Default RE: 3.73 install guide
wow. good luck. there was a member on here that installed the gears himself. cant remember who right now but i will post back if i find out.
Old Jun 25, 2008 | 01:07 PM
bigdaddy0987's Avatar
bigdaddy0987
word to the wise if you havent ever done this before dont try it. it is really easy to mess something up. it isnt as simple as it seems. but i dont know maybe you will knock the bottom out. im just speaking from experience
Old Jun 25, 2008 | 01:12 PM
mustangman02232's Avatar
mustangman02232
the tlok is acutally doable for a DIY but if your changing gears then you need to know about backlash and how to set it up properly which i would let someone do, so they mise well do both while they are in there
dont forget a bering kit
Old Jun 25, 2008 | 08:33 PM
my first mustang's Avatar
my first mustang
Its much better to have someone with the knowledge and tools to do this job right. Its very easy to screw up and it will sound terrible! This is a job for a professional. This is the reason I went with a 8.8 takeoff when I wanted gears & t-lok.
Old Jun 26, 2008 | 11:28 AM
Sancho805's Avatar
Sancho805
does anyone know the weight difference between the 7.5 axle assembly and 8.8 axle assembly?
Old Jun 27, 2008 | 10:44 PM
mustangman02232
ORIGINAL: Sancho805
~80 lbs
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
SilverStallion05
Sep 5, 2015 10:48 AM
