Problems with the x
Old Jun 29, 2008 | 10:26 AM
05v6hornet's Avatar
05v6hornet
Default Problems with the x
is anyone else haveing problems with their x-charger not giving enough boost ?
Old Jul 1, 2008 | 09:58 AM
pat6674u's Avatar
pat6674u
Default RE: Problems with the x
Huh? Boost is controlled by the tune and no, my X is almost always in boost. 5-6 psi for cal spec and I think 10psi for the hi-po.
Old Jul 1, 2008 | 12:23 PM
GrayPony's Avatar
GrayPony
ORIGINAL: 05v6hornet
How did you determine that thereis not enough boost??
How much boost are you seeing? what kit, Hi-Po or Cali?
Old Jul 4, 2008 | 09:26 PM
Trill Gear Head's Avatar
Trill Gear Head
ORIGINAL: pat6674u
On a supercharger the boost is actually controlled by the size of the pulley that is being spun.
Old Jul 4, 2008 | 11:05 PM
fazm's Avatar
fazm
ORIGINAL: Trill Gear Head
ORIGINAL: pat6674u
exactly, at least with the xcharger setup (i believe the cobalt ss/sc limits boost in 1st gear somehow)
Old Jul 10, 2008 | 10:14 PM
05v6hornet's Avatar
05v6hornet
i have the hipo kit and sometimes at wot the boost gauge reads 0 and the car is slow
Old Jul 11, 2008 | 05:45 AM
GrayPony's Avatar
GrayPony
Check the bypass valve maybe something is hanging it up.
Can you replicate the problem or does it come and go?
Describe the situation when it happened last... (the event)
Old Jul 11, 2008 | 10:00 AM
pat6674u's Avatar
pat6674u
vac hose is loose from the t-fitting.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
