somebody please help
Old Jun 29, 2008 | 04:29 PM
leobound's Avatar
leobound
Default somebody please help
Ok here's the problem.... 2005 V6 manual trans, 38,xxx miles, sparatically while either the clutch is in or the car is out of gear it revs to anywhere between 2k and 2500RPM for absolutely no reason. Sometimes worse than others....sometimes not at all.... Can somebody please tell me what the he** is going on? I'm sure it's a simple fix and probably overlooked by me numerous times. I just can't nail it down. Thanks in advance.
Old Jun 29, 2008 | 08:52 PM
Yellow Tang's Avatar
Yellow Tang
Default RE: somebody please help
Ok I’m no pro but I would try checking the fuel filter if it is not flowing well and starving the car it may lean it out = short higher RPM burst but I am probably wrong. Try this or go to Dealership
Old Jul 1, 2008 | 12:47 PM
billybix76's Avatar
billybix76
Mine did same. . The problem is in the factory tune. It will rev to make it easier for grandma to shift into lower gear when coasting, however the ford factory tune has this little "throttle lag" issue where the car still thinks your moving faster than you are and it is very slow to come down, If you press the clutch while low speed coasting you should be able to force it to drop to idle and can determine if this is the issue. If it does, then the only way to fix it is to get the "coasting fuel shutoff" parameter changed with an aftermarket tune. Send an email to Justin at VMPtuning.com, or Doug at Bamachips.com for help.
Old Jul 1, 2008 | 08:14 PM
Yellow Tang
There you go someone that knows what is going on with this I have a manual shift but have never had this happen to me Thanks billybix76 good job.
Old Oct 20, 2008 | 06:17 PM
jpac's Avatar
jpac
Thanks for the info guys, I have the same problem.
