Max Boost On Stock Internals?
Old Jan 5, 2009 | 12:18 AM
Mattwood440's Avatar
Mattwood440
Default Max Boost On Stock Internals?
So I went ahead and got a Procharger kit and will be installing it in the spring. I wanted to start a thread and hear from those who are running boost what psi are you running and for how long on the stock pistons, head gaskets, etc.
Personally, I'm planning on starting with the lowest boost/biggest pulley until I get into the engine.
Probably should say what forced induction system you're using too.
Old Jan 5, 2009 | 12:28 AM
fazm's Avatar
fazm
coming up on 2 years running 9-14psi, daily driven car, 40-50 miles minimum a day (minimum 6 days a week)
Old Jan 5, 2009 | 12:30 AM
86_GT_Mustang's Avatar
86_GT_Mustang
Cant afford a v8 but you can afford an FI..
Anyway i would do 7-12psi on stock
Old Jan 5, 2009 | 12:41 AM
Mattwood440
Do you mean you changed the boost over that 2 year period? Procharger or what? 14psi or even 12 sounds a little high for cast pistons with 9.7:1 comp, not to mention pump gas.
Old Jan 5, 2009 | 03:11 AM
Avalanch3's Avatar
Avalanch3
fazm has a turbo setup, just read some of his previous posts and you can find his setup.
Old Jan 5, 2009 | 05:34 AM
GrayPony's Avatar
GrayPony
Where did the OP say he couldn't afford a V8?
Old Jan 5, 2009 | 05:46 AM
rygenstormlocke's Avatar
rygenstormlocke
I wouldn't go above 13lbs of boost.
Old Jan 5, 2009 | 10:50 AM
Dwisforme05's Avatar
Dwisforme05
thats pretty uncalled for. i couldnt afford the v8 but somehow i managed to get and s/c. why? cuz i found a hell of a deal on it. that comment was unnecessary.
anyway, i would listen to todd, he knows his stuff inside and out. same with dave. i too wouldnt go over 13-14lbs.
Old Jan 5, 2009 | 12:16 PM
rock61992's Avatar
rock61992
i think he was refering to Fazm's sig...
Old Jan 5, 2009 | 04:40 PM
Mattwood440
Ok. Both of their setups are turbo. No blown head gaskets? Any SC numbers out there? I know boost control on a TC is very different from an SC. Procharger tech person said I should have no problem with the 9psi pulley, but according to supersixmotorsports.com they have seen blown head gaskets at only 8psi.
http://www.supersixmotorsports.com/pdf/40SOHCTech.pdf
