Failsafe mode/TB question, help please
Old Jan 17, 2009 | 12:35 AM
tx_zstang's Avatar
tx_zstang
Make sure it's all plugged in good, too. The connectors should all be solidly in place and connected.
Old Jan 17, 2009 | 08:54 PM
sdsguy's Avatar
sdsguy
not to make you sound like an idiot, but is your MAF sensor connected? once i was putting in my CAI and forgot to connect the MAF sensor to the cable and i was getting a failsafe mode readout too when i stepped on it.
Old Jan 17, 2009 | 10:46 PM
will's Avatar
will
Make sure you heat up the screws on the tps they have very good locktite in them and hold very well. Don't heat it up and they snap off!
Old Jan 19, 2009 | 01:22 PM
RobbieCopp's Avatar
RobbieCopp
yeah Iit is, I checked everything yesterday, but i was also getting it before I put in the CAI too. Also, right at the intersection next to the Ford dealer yesterday, right when the light turned green the car went in to FS mode and wouldn't move so I had to restart the car before I could go. And to make things worse I was the first person at the light! But I forgot it was Sunday yesterday and that the parts dept is closed, so I'm going to go right now before work.
Old Jan 19, 2009 | 11:03 PM
RobbieCopp's Avatar
RobbieCopp
I went to Ford and got the TPS and put it in tonight. 91 bucks . Bright side is, I got to take a peek at some Roush and Shelby mustangs. Anyways, I put it in, and the light didn't go away so I checked the codes again and was still getting the same code, hit clear codes ad the light went away. If it comes back on I'm gonna take it to the shop to get checked out.
Old Jan 19, 2009 | 11:23 PM
up_yours_7's Avatar
up_yours_7
Well unless you disconnected the battery for 15 min it wouldn't of reset the light hope it works for ya
Old Jan 19, 2009 | 11:32 PM
RobbieCopp's Avatar
RobbieCopp
Oh you disconnected the battery to get the light to go away after the swap?
Old Jan 20, 2009 | 08:41 AM
up_yours_7's Avatar
up_yours_7
I disconnected the battery did the install then plugvthe battery back in 15 min later and it worked great
Old Jan 20, 2009 | 02:10 PM
RobbieCopp's Avatar
RobbieCopp
Ohh i see. Well disconnecting the battery will take the light away anyways. Thats what the Ford guy told me to do last time, just to make the light go away.
Old Jan 20, 2009 | 03:54 PM
tx_zstang's Avatar
tx_zstang
Disconnecting 'resets' the learned values in the computer (the KAM, Keep-Alive-Memory). You can also do clear of dtcs from a tuner device (or issue a specific OBD command if you have that capability).
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
