What should i do?
my engine light just recently came on and i plugged it into a computer and got the code and such for it and was just wondering what i have to do to deal with the problem, heres the code information:
P2068 - Fuel Level Sensor "B" - Circuit High.
Thanks
Thanks
Was your tank replaced or serviced (part of tank-filling-problem tsb)? If so, the connector might not be plugged in all the way on the fuel pump module. It's easy to get to: removed the back seat (use the 2 tabs on the bottom to pull it loose, then remove it), and remove the black plastic round cover under the seat on the driver side of the car. There's your fuel pump connections. Check both of them and make sure they are plugged in, and visually-inspect the wiring leading away as far as you can.
well me and casey(up yours 7) checked out the area where the junction box is and he said it was a bit damp and it rained today so im gonna see if it is wet still so i may need to get that fix done before it shorts everything but i dont know if the tank has been replaced the guy i bought it from said that he didnt have any problems with it so i doubt it
