What is the difference?
Old Oct 3, 2009 | 01:00 PM
wetwille3's Avatar
wetwille3
Default What is the difference?
What is the difference between a Ford Racing limited slip differential and a Ford Racing T-Lok? These are the two sites. I might get gears and was wondering which to go with.
http://www.stangmods.com/Mustang-Gea...ds-p/00346.htm
http://www.americanmuscle.com/ford-28spline-75-lsd.html
Old Oct 3, 2009 | 01:18 PM
So_Cali's Avatar
So_Cali
Its the same thing bro, just a different name..
Old Oct 3, 2009 | 01:30 PM
wetwille3's Avatar
wetwille3
I thought it might i just read that one is better for drag racing
Old Oct 9, 2009 | 03:02 PM
wetwille3's Avatar
wetwille3
Then what about a t lok and a true trac?
Old Oct 10, 2009 | 07:46 AM
Torch_Vert's Avatar
Torch_Vert
T-lok is a standard limited slip. Work great, but does feature wearable clutches (see photo), and with enough use WILL require periodic rebuilds to maintain functionality.
The TrueTrac is an all steel unit, that works with a gearing setup to do the same job.
The Truetrac isn't susceptable to requiring regular rebuilds, and works great, but the trade off is it costs significantly more initially (over the long haul it's cheaper though as you're not paying labor for rebuilds)
Old Oct 10, 2009 | 09:40 AM
IndecisiveS197's Avatar
IndecisiveS197
the clutch type LSD is the more effective LSD in zero-low traction situations.
The clutch type LSD will always be connected in SOME way, whereas, the helical LSD will unlock/uncouple if one wheel has zero friction(driving in very slippery conditions like ice, or if one wheel has lost contact with the ground).
So, although the clutch type LSD needs servicing once in a while, it's generally the more effective type of LSD.
Old Oct 10, 2009 | 09:41 AM
IndecisiveS197
oops double post
Old Oct 10, 2009 | 03:58 PM
Torch_Vert's Avatar
Torch_Vert
I don't dispute your statement regarding extremely low to zero traction situations, but most people adding a limited slip to a Mustang aren't really doing so with operation on sheet ice or off road rock crawling in mind
I have used my Truetrac in some New England winter conditions that I truly wish my car didn't have to be out in. The Truetrac performs flawlessly in normal snowy/icy situations.
Old Oct 11, 2009 | 12:30 PM
wetwille3's Avatar
wetwille3
Alright thanks and how often is it nessecary to rebulid the clutches?
Old Oct 11, 2009 | 03:15 PM
V6Vin's Avatar
V6Vin
In regards to the Truetrac and zero traction situations it is my understanding that if you just tap the brake it will sense resistance and lock up the other side.
I am curious like wetwille3 about length of time between rebuilds on average for the T-loc with just "spirited" driving, no track use, Anyboby?
Dokilar
15
Oct 16, 2015 08:13 PM
breaking
Oct 2, 2015 01:27 PM
UrS4
Sep 30, 2015 10:13 AM
mrappe
Sep 26, 2015 10:16 AM
