starting problems
Old Aug 7, 2010 | 06:50 AM
tjf96gt's Avatar
tjf96gt
Default starting problems
about two months ago i put alluminum underdrive pullies on my 4.6L. almost imediatly i had trouble getting the car to come up to idle after i stared it. but it would not do this every time. so i replaced the fuel filter which wasnt really that old. this seemed to help at first then it did it again. i stared letting the fuel pump pressure up before i tried to start the car and this helped out for a while. then it slowly was giving me trouble until yesterday i cant get the car to stay running with out keeping my foot on the gas and it still runs like ****. again i replaced the fuel filter thinking this could be the problem but it did nothing. i cant help but feel like this was never a problem until i installed the pullies.
Old Aug 7, 2010 | 09:12 AM
157dB's Avatar
157dB
Cut & Paste Expert
Maybe its a leak somewhere in the air intake caused from
improper reinstallation after the underdrive pully install.
Have you tried to reset the adaptive learning?
Disconnect the battery for 20 mins and follow the relearning procedure
in the owners manual...
Sometimes underdrives will overtax an already overtaxed alternator
and cause low output at idle.
Whats the battery idle voltage doring the no idle problem?
Old Aug 7, 2010 | 11:07 AM
tjf96gt's Avatar
tjf96gt
20 mins, i ony did mabe 10 mins. i will have to look that up in the manual i didnt know about that. i will also check the voltage that makes perfect sense.
Old Aug 7, 2010 | 11:53 AM
tjf96gt's Avatar
tjf96gt
i looked in the owners manual and found nothing on adaptive learning. where else can i find that infomation?
Old Aug 7, 2010 | 02:29 PM
157dB's Avatar
157dB
Cut & Paste Expert
Look for it in the , wait, wait, wait, wait,
battery replacement/disconnection area.
Old Aug 7, 2010 | 05:02 PM
2005Redfire6's Avatar
2005Redfire6
I would leave it off for about an hour just so you know its good to go resetting wise.
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
