Squat Bracket?
Old Sep 4, 2010 | 12:57 PM
sick_sixxer's Avatar
sick_sixxer
Default Squat Bracket?
Simple question, what is a squat bracket??
Old Sep 4, 2010 | 08:44 PM
JimC's Avatar
Super Moderator
I think what you are referring to is the LCA relocation bracket, which is sometimes referred to as an "anti-squat" bracket.
It is used to change the angle of the LCA so that the bottom is not pointed up, which is a bigger problem on lowered cars. You want the LCA to be parallel to the ground or lower in the rear to get the most traction off the line. If it is angled up, then you the power actually pushes the rear end up so you get less traction.
I use the UMI bracket in my set up. I can't find any installed pictures right now but this links you to the bracket and a picture of it. I'm sure that someone has a picture of their's installed.
http://www.umiperformance.com/catalo...roducts_id=319
Old Sep 5, 2010 | 08:20 PM
sick_sixxer
Thanks bro alot of help
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Oct 7, 2015 07:02 PM
Explosive
Oct 2, 2015 07:45 AM
