CAI Tuninbg Question
Old May 12, 2011 | 11:44 AM
rodtod11's Avatar
rodtod11
Default CAI Tuninbg Question
Sorry....new to this stuff..but...I was checking out American Muscle and saw that some CAI systems came with a tuner and some did not. Also, some said "Needs Tune" and some did not. If you install a cold air system will the car set the computer accordingly after driving it a while? My Escape does reset the computer in certain conditions to relearn idle and shift points.
Or...is it just better to get a tuner with the CAI? I noticed a BIG cost differance.
Old May 12, 2011 | 01:18 PM
05windviel's Avatar
05windviel
Well there are some CAI that don't require a tune but they really don't do that much. If you get a Cai with the tuner it also has custom tunes i believe, and as most people this is one of the best things you can do to your car. I just recently got a tuner for mine and it makes quite a bit of difference you'd be best off getting the combo if you can afford it otherwise wait till you can because its better to get the combo than to buy one that doesn't require a tune because you might not get as much of a gain from a intake that doesn't require a tune.
Old May 12, 2011 | 01:56 PM
rodtod11's Avatar
rodtod11
Thanks! I think I will do just what you said. It sounds like what I want is a good CAI with tuner and the Borla exhaust. Not looking to break speed records, just run smoother with a good exhaust tone.
Old May 12, 2011 | 01:57 PM
Nuke's Avatar
Nuke
No-tune-required CAI's do little with regard to performance gains as the PCM can make only minor adjustments for the additional air flow. Plus, some PCM's will still throw a code for running lean, even with a no-tune-required CAI. A CAI & tune combo will gain you about 4-5 times the power that a stand-alone CAI will gain. Do it right the first time.
Old May 12, 2011 | 02:02 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Ditto, CAI with no tune is like a nice chick's bikini top the girl wearing has no ***** for it! What's he point?
Old May 12, 2011 | 02:31 PM
kevinmalec's Avatar
kevinmalec
I have an Airaid CAI, which does not require a tune, but after the installation I only felt minimal performance gain, maybe 3-5 HP in the higher RPM range. However, once I uploaded the custom tune, I felt a drastic change w/ the throttle response and HP! CAI/Custom tune combo is the way to go!
Old May 12, 2011 | 02:39 PM
rodtod11's Avatar
rodtod11
That's an interesting idea! What does a custum tune cost? If I bought a tuner with CAI I can't see that I would need it again.
Old May 12, 2011 | 02:46 PM
kevinmalec's Avatar
kevinmalec
If you buy a CAI/tuner combo from AM, it typically comes with 3 custom tunes. You choose the tunes according to the octane available in your area. Example: I have the following custom tunes for my car (87 - 89 - 91). You will need the tuner to change your tunes or set it back to stock, when needed.
Old May 12, 2011 | 07:41 PM
Nuke's Avatar
Nuke
Originally Posted by Derf00
...CAI with no tune is like a nice chick's bikini top the girl wearing has no ***** for it! What's he point?
At least the girl with no ***** may still have some "talent" and can "perform", unlike a no-tune-CAI (I never met a woman with 2 sets of lips I didn't like).
Having the tune also means that you can adjust some other minor parameters to resolve your speedometer issues due to gear and tire size changes in addition to a few other parameters. Also, as you continue to mod, you can get revised tunes to suit.
Old May 12, 2011 | 08:00 PM
Alec's Avatar
Alec
Hahaha
But OP, get the tuner with the CAI or don't bother, and it's well worth it.
