Blinking Engine Light 2006 V6 ?
Old Jan 5, 2012 | 09:23 AM
lwpskins's Avatar
lwpskins
Default Blinking Engine Light 2006 V6 ?
Changed crackshaft balancer. Since then error code for cyllinder 3&4. Changed wires and plugs but when on highway blinking engine light came back on. Any1 have clue on what to do?
Old Jan 5, 2012 | 10:49 AM
Timspony's Avatar
Timspony
SVT Section Moderator
Welcome to MF! .... need to check on the S197 V6 section!
Old Jan 5, 2012 | 11:11 PM
Stang-aholic's Avatar
Stang-aholic
try taking off the wires and making sure none of the caps are burnt. you can also check and clean the MAF, ive heard it helped a few ppl. then if that doesnt work, i would probably take it in. it sounds like spark or fuel tho
Old Jan 6, 2012 | 12:54 AM
tx_zstang's Avatar
tx_zstang
What's the specific DTCs (codes)?
How does it run?
Old Jan 11, 2012 | 08:24 AM
JRC702's Avatar
JRC702
A flashing engine light is usually the result of an engine misfire.
This happened right after replacing the crankshaft balancer? If so you have to assume it is related to that. Does the ECU get it's ignition reference signal from the balancer?
That's where I would start.
Old Jan 11, 2012 | 11:16 PM
tx_zstang's Avatar
tx_zstang
No. GET THE SPECIFIC CODES AGAIN. Go from there.
A 'flashing light' can mean lots of different things. These cars have a lot of built-in monitoring and diagnostics. Use it!
djbigskrilla
Sep 20, 2022 01:04 AM
J.casone400
Aug 28, 2015 09:33 PM
kevans79@yahoo.com
Aug 18, 2015 08:16 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
