Speedometer Color
Old Apr 12, 2015 | 10:14 PM
codyandrew5995's Avatar
codyandrew5995
Default Speedometer Color
I have an 07 model V6. When I turn my lights on my speedometer turns an ugly green. What is the cheapest way to change the color of my speedometer?
Old Apr 12, 2015 | 10:43 PM
cruisin5268d's Avatar
cruisin5268d
Welcome to the forum!
I'm guessing you do not have the MyColor option? If you do, then just change the colors using the buttons.
If not, then I am not sure what to tell you. There are members here that have experience with such things and I'm sure someone will chime in and give you something more solid.
Old Apr 18, 2015 | 03:41 AM
Nuke's Avatar
Nuke
If you don't have the "MyColor" option (refer to your OM), then the previous owner must have replaced the cluster bulbs. With the MyColor option, you can change the cluster to virtually any color.
Old Apr 18, 2015 | 06:53 AM
Bitter's Avatar
Bitter
With or without MyColor, all of the gauges should be the same. If it is only your speedometer that is an ugly green, as Nuke said, someone replaced a burned out bulb with the wrong one.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
popsotto
Sep 28, 2015 06:58 AM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
