Coolant leak
Hey I have a slight leak I can visually see where it is but I don't know what part it is and I won't lie I don't know a ton about cars. But I would rather fix it myself if I can get someone to identify the part I need to replace or how to fix it
Your coolant is leaking on the forum making it difficult to use the forum?
You posted in the wrong section. This is for problems using the forum - i.e. logging in etc.
Every generation of Mustang has its' own section. That is where you post about your specific issues with your car.
Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
Most likely it is the thermostat housing then - very common failure. The plastic splits and you lose coolant; quite often mistaken for a water pump leak because of how the coolant runs down.
Lot of information about it in the S197 V6 section
