3650 and my problem..
sometimes my 3650 doesnt slide through gears as smooth as i feel it should. i have my mgw short throw installed its nice. whats next is should i fix the syncros? because it feels like theres something in the way sometimes through 1st to 2nd and 2nd to 3rd. If anyone is familiar with this let me know..
would a new performance clutch fix this?
I have the same problem (I have the T45). There is a TSB on the 3650 for it. Supposedly new synchros will remedy your problem. Also, do you notice if it only does it when it is cold? I know mine does....
it just is like once in a while. idk maybe its cold or something but sometimes it just feels horribly ****tty and somtimes its great and i can powershift like nothing..
yeh i saw the tsb.. does my warranty cover for ford to fix those syncros?
putting a clutch really wont help the problem that you have, I too have the same problems in my 3650, and bottom line is that the synchros ae junk. Ford has a TSB on this, you can do some research on the subject and possibly coax ford into fixing it for you. If Ford wants to replace the whole tranny, I would be hesitant because a lot of people on here have had it replaced rather than fixed and they run into the same problem. Id make sure that they installed the better synchros in your existing tranny. I have yet to go to ford about this, but I will...hope this helps....
same problem with mine, took it to the dealership and they replaced my scyncros and a shift fork i believe... it was under warranty and the day i got it back i slapped on a MGW.. works like a dream
How many years does this defect effect. My '04 is a B**CH to shift when it is cold, especially with the short throw TRI-AX. My wife's '01 Bullitt shifts like butter, and that's an early 3650 and she has 5K less miles than me. (Maybe I'll send her to Florida for a weekend with the girlies and swap trannies) He, He!
John
John
ORIGINAL: MustangMafia
3650 is garbage, clutch is garbage, throw-out-bearing is garbage, the work and parts that ford puts into them is also garbage. they will never fix the problem, they will fix your tranny then 20,000 miles later it happens agian. just gatta live with the ****ty 3650.
ORIGINAL: StickShifty
